procedure for Aficio 2035 SMB setting
  • hknwbec
    • 214
    hi , could you tell me the right procedure for setting SMB on Aficio 2035 copier. As I want to setup scan to folder on the network pc. Thanks
  • sandmanmac
    • 3990
    Re: procedure for Aficio 2035 SMB setting
    Impossible, unless it is 2035E model. Can only scan to folder on 2035 with "Scanrouter" software, and there are dozens of threads describing both "Scanrouter" and 'SMB' configurations on this site already
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      sandmanmac is right on!! Forget scan router as it's no longer supported and does nothing but make you beat your head against the wall !!!!!!!!
      Mystic Crystal Revelations
      • fbkhan3
        • May 2012
        • 421
        Agree with M8S..Only possible option for scanning is via desktop binder and Network TWAIN Driver,
        NO SMB option for this model.
