Issues printing to SPC 401 DN from Mac 10.7.4
  • mikadonovan
    • May 2008
    • 2931
    Ugh. We're in new territory with this as we normally don't support Mac os. The issues are: How do we save the printers configuration without having to reinput it every print job? Also, there is no option to select heavy glossy stock when printing pictures. These may be easy fixes. I don't know much about this OS. The printer does have postscript installed. We are using the PPD installer for 10.7 from Ricohs driver website.
    BTW, correction. It's a SP C410DN. Lysdexia sucks.
    NEVER ASSUME ANYTHING
  • Chameleon
    • Nov 2011
    • 200
    Re: Issues printing to SPC 401 DN from Mac 10.7.4
    The Cups interface will help you save default configuration settings. Open a web browser and go: " Http://localhost:631 " You may be prompted for an admin password depending on their setup. If you can't find a Heavy glossy stock setting there it probably isn't supported by the PPD you are using.
    The chance that higher life forms might have emerged in this way is comparable to the chance that a tornado sweeping through a junkyard might assemble a Boeing 747 from the materials therein. -Fred Hoyle
    • mikadonovan
      • May 2008
      • 2931
      We'll give that a try. Thanks for the response.
