Ricoh MP6500 MP5500 MP7500 lcd display lamp out. Source for lamp?
  • Copytech
    • Feb 2011
    • 8
    I have 2 Ricoh mp6500 machines that have a bad lamp for the touch screen . Does anyone know if you can buy the lamp seperate ? If so, a part # and source would be appreciated. Thanks
  • mikadonovan
    • May 2008
    • 2931
    Re: Ricoh MP6500 MP5500 MP7500 lcd display lamp out. Source for lamp?
    I would say the problem would be in the LCD itself...
    B238 1485 LCD STN W-VGA
    or the invertor...
    B238 1486 Invertor STN
    If you have a spare op panel in shop for parts, I would try replacing the invertor first.
    NEVER ASSUME ANYTHING
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      Nation Wide Repair Service
      Mystic Crystal Revelations
      • rthonpm
        • Aug 2007
        • 2847
        I'd tend to agree with Mika that the inverter may be the issue more than the CFL. I see this quite a bit with laptops. If you have a op panel on a working machine in your shop, try swapping the inverters.
        • Copytech
          • Feb 2011
          • 8
          Is the invertor the small board the lamp plugs into? I know that on one, the lamp is physically broken. So is the invertor a commom problem? On the older Minolta's, I have changed several of the cfl's that went out and could buy them for about $10.
          • Zoran
            • 44
            aficio 1060 ft series lamp
            • Zoran
              • 44
              or led strip
              • Zoran
                • 44
                I have my MP 5500 connected to PC monitor
                • Zoran
                  • 44
                  In many services, these problems appeared lately
