MP C3501 scan via Imap
  • iscott
    • Mar 2010
    • 344
    I know this one is SSL but have not found the setting. The ISP is a University and no POP 3 is available....
    Never set one up like this...
  • alp
    • Jun 2012
    • 39
    Re: MP C3501 scan via Imap
    The ssl setting is on the control panel, with SMTP server. Not on web page.
    • alp
      • Jun 2012
      • 39
      I assume you are just setting it up to send email, so you are using SMTP. IMAP and POP are for the machine to recieve email. You dont want to go there.
      • iscott
        • Mar 2010
        • 344
        well where should i go?
        • alp
          • Jun 2012
          • 39
          Is the customer wanting to recieve emails on the copier? For what purpose? This only works sending documents from one Ricoh to another Ricoh like a fax. Is that what they are trying to accomplish?
          • iscott
            • Mar 2010
            • 344
            just standard email The email server only works in Imap or so is my understanding.
            • rthonpm
              • Aug 2007
              • 2859
              IMAP is a reception protocol, SMTP is a universal sending protocol so it doesn't matter if the reception standard is POP or IMAP. The same server may be doing the same job so the server name should be the same.
              • Choro1dal
                • Jun 2008
                • 176
                Although POP and IMAP are protocols used for receiving emails thay can also be use to enhance SMTP authentication.
                In User Tools > System Settings > File Transfer it is possible to enable POP before SMTP. By default this is off , if you set POP before SMTP to On, you can set the waiting time after authentication, user name, e-mail address and pssword.
                Also, If you enable POP before SMTP you will need to enter server name and port configuration in POP3/IMAP4 Settings.
