Is this correct?
  • tinnyjay
    • Oct 2009
    • 663
    Is this correct?
    Somebody sent me firmware for Ricoh Af2090 but i need to know if this firmware is correct.
    "Who loves the roses,must also bear thumbs"
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: Is this correct?
    [ATTACH=CONFIG]16246[/ATTACH]
    Here's what is current in the USA.
    AFICIO_2090.pdf
    Mystic Crystal Revelations
    • tinnyjay
      • Oct 2009
      • 663
      [ATTACH]16247[/ATTACH]
      I took a Sony SD Card 2 GB and put it in C3 as SM says,but nothing happens.
      Please can you help me how to proceed?
      After i put SD card in,i can do NVRAM Upload,download.
      How should files must be in sd card,in a folder or without a folder?
      Please help me.
      • Zeldaman
        • Mar 2011
        • 946
        Hi there!
        Look at "sd-card specs".
        Greetings...
        • tinnyjay
          • Oct 2009
          • 663
          Originally posted by Zeldaman
          Hi there!
          Greetings...
          Must be maximum 2 GB (my sd card is 2 GB,but knows only 1.83 GB ).
          I didnt knew that files must be rooted in a folder named romdata*
          I haved to try tomorrow
          • Gift
            • Mar 2011
            • 2459
            have you tried formatting the card with the "panasonic sd-card-formatter" tool? You'll find it for free via google.
            Not to forget:
            Even if the size of the card is within the specs, some brands just don't work (on some machines). So if you're doing it by the book and with a proper formatted card, you should try another one. (Sandisk, Toshiba, Transcend..)
