Ricoh Aficio 2090 Copy Document Server files problem
  • elredeany2010
    • 13
    I've douments in 2090 document server, the Documents stored with the copy feature
    I need to copy them into my PC
    I used Desktop binder
    but when i need to copy these files there is a problem:
    device option is required to transfer copy and printer data stored
    in the document server (206-202)
    I need to know about File format conversion ....! what is it?
    is it an application I install it? or What?
    Plzzzzzzzzzzz Help me
  • zed255
    How'd ya manage that?
    • 1025
    Re: Ricoh Aficio 2090 Copy Document Server files problem
    It's a hardware add-on card called a File Format Converter or also known as a Media Link Board. You can't retrieve the document server contents without it. The only other option is to print everything and rescan it, or simply rescan the originals if they are available. Also, if electronic originals are available they can be 'printed' to the document server using the appropriate option in the print driver.
    • elredeany2010
      • 13
      How can I get this hardware add-on (file format converter)what is look like ...?is it like a blue SD Card (printer, scanner and pot script)
