Ricoh 3224c yellow dot across page
  • aivars
    • 11
    Has anyone seen something like this
    yellow dots are printed on all pages
    all dots are precisely in specific order (attached scans are not in better quality, some part of dots is not visible)
    its happen from all source: copy, print, pattern
    BW, single MC printouts is ok
    in attachment is scan in BW mode from C printout pattern 11 (SP5-955-1)
    C developer unit was installed in position of Y developer for this printout
    sorry for english
    look forward to any ideas
  • Zeldaman
    • Mar 2011
    • 946
    Re: Ricoh 3224c yellow dot across page
    Hi there!
    This phenomen occurs on all modern colour copiers/printers. In that "code" is the serial-no & printdate & -time.
    Greetings...
    • Jomama46
      • 2900
      Thats news to me. I know you get that code if you try to copy bank bills or such. This looks more like a pcu belt.
      sigpic
      A+; Network +; PDI+
      • teebee1234
        • Jul 2008
        • 1670
        It is true that all (or almost all color printers and mfp's) print a specific matrix pattern with yellow dots that is unique to each device. This is an anti counterfeiting measure that will allow the Secret Service to back track illegal prints to a specific machine. You shouldn't be able to notice them normally with the naked eye but if you put a loop magnifier over the page you can see them or a blue led flashlight will make them really pop out. One organization (EFF.org) has deciphered Xerox Docucolor so far (may be more by now), turns out if the pattern is looked at with an x and y axis (vertically (x) 1 to 8, y I'm not sure) the dots correspond to a binary value. The group was able to decipher the Serial number, manufacturer, time stamp and some unknown value. Granted the devices can read many items that are illegal to copy by unique characteristics and produce a 'blackout', but not all. These yellow identifiers could also be used to backtrack copying of proprietary company info or even a letter from the next Unabomber.
        Though this is a no no to talk about within the company, it's not a classified secret. Just don't go asking about it at the office is probably the best advice.
        Here's a link to a site that really hates this....EFF1 EFFyellowdots
        On a personal note, this organizations (EFF) main beef is that this is a violation of privacy, human rights, blah blah blah. I don't buy that if the mfp is owned by an employer or government agency (basically you don't own it so you can't bitch). I can see an issue if it was a personally owned device, then I may try and determine if there was some way to disable it or find a manufacturer that doesn't utilize it.
        • Tonerbomb
          AutoMajical Resolutionist
          • Feb 2005
          • 2589
          Zeldaman and TeeBee are right on the money!! I learned of this in my first Ricoh color class the Fabulas 2003 machine.
          Mystic Crystal Revelations
          • Ricohslave
            • 27
            As Zeldaman and Teebee1234 said, it is a unique code relating to that copier.
            As far as I know all Ricoh digital colour copiers have produced it. The pattern is only visible using a magnifying glass.
            • Llama God
              • Mar 2009
              • 1353
              I'm not convinced that the plethora of dots on your scans are the identifying dot. Isn't there normally one per page?
              • Llama God
                • Mar 2009
                • 1353
                Although having watched the 2 crazy conspiracy theorist tossers on the video I could be wrong.
                My printer's plotting the downfall of democracy, kill 'em all. Kill the masses.
                • Hansoon
                  • Sep 2007
                  • 3401
                  Those dots are squares. Don't know how your scans are made with what resolution but if the original is the same than I suspect a laser driver circuit issue.
                  Hans
