MP 7500 older firmware
  • imthinman
    • Jun 2008
    • 36
    I need a little help. I need the oldest version of firmware for the MP7500. The newer versions do not work with scan router lite and I am stuck with a customer (60 machines) that has one machine that will not connect and customer can not upgrade scan router at this time. The web site does not have any versions but the newest and the one prior. Any help or info about which settings need to be changed to allow it to connect with v2 lite will be appreciated.(bcollins@imagingexperts.net)
  • zed255
    How'd ya manage that?
    • 1024
    Re: MP 7500 older firmware
    You should be able to get all versions from Ricoh's e-Source website, just check the info on the firmware file and you should be able to go bak to any official version. Some intermediate 'factory' releases will not be available.
    • rthonpm
      • Aug 2007
      • 2858
      Is ScanRouter an absolute necessity? Ricoh doesn't officially support it anymore as Samba is a standard package in most machines now. Clients may be reluctant to change, but sometimes it is for the better.
      Good luck.
      • mikadonovan
        • May 2008
        • 2931
        Good luck.
        X2. Why are you using scanrouter with this box?
        NEVER ASSUME ANYTHING
        • dradisic
          • Jun 2016
          • 11
          Hi all,
          And I needed firmware for Aficio MP 7500.
          I have a machine MP7500 which have the German language menu, I need to change the language to English but seems to have to change the firmware.
          Which are correct firmware, for printer, System Engine, LCDC and NIB.
          On my machine I have instaled only German language and all the functions are in German, I do not understand, and so I need the English language menu.
          Is there any other way to change the language display menu from Deutsch to English.
          Attached I send you a document with the configuration list,
          Please if anyone can help me on this issue, unfortunately I do not have access to the ricoh portal to download needed files,
          Thank you in advance and best regards,
          Darko
            • 37513
            Are you sure that Scan Router is setup properly on the 7500? Check setting between this machine and another one that works. Also submit the SMC diagnostics print for both so we can compare and determine what firmware you might need.
