aficio 1035 SC322
  • hknwbec
    • 214
    aficio 1035 SC322
    Hi, As I don't have this service code informations. could you let me know how to fix this problem. and If I instale the network printer card, what data should I need to input in the service mode. thanks
  • sakura
    • 132
    Re: aficio 1035 SC322
    Usually this code is related to a laser unit issues. For example (and it could apply to 1035 model) that SC code is called "Synchronization error" in Aficio 3035/3045 model.
    Cause: The synchronization signal was not issued within 500 ms after the LD fired while the polygon motor was turning at the prescribed number of revolutions.
    Resolution:
    • Laser synchronization board connectors loose, disconnected, or damaged
    • Laser synchronization board defective
    • LD drive board defective
    Try use SP2109-003 - Laser sync 400dpi then do SP2109-004 Laser sync 600dpi. Its a common issue with these old models.
    Hope it helps. Good luck!
    • hknwbec
      • 214
      Laser Unit
      Could we use aficio 2035 laser unit install on aficio 1035
      • sakura
        • 132
        Re: Laser Unit
        No, you can not. They are totally different machines. You can use a laser unit from Aficio 1045 on Aficio 1035 and vice verse. That is it.
        According to your profile's location - you are from China.
        Part # for Chinese market is B003 1877 - Optical Housing Unit(EU/Asia/CHN)(B003) (laser unit assy)
        • neergish
          • 177
          have you checked the front door switches and upper right door switches?
          "See if you can rent a spring hook and a phillips screwdriver it will make your life that much easier..."
          • sandmanmac
            • 3981
            With all due respect, you have 170 posts here, so you're a veteran user, yet you have not even bothered to search the site either with the built in search engine or google. There must be no less than 50-100 threads dealing with this problem.
            Let me help by suggesting you "google" this for starters:
            aficio 1035, sc322 site:copytechnet.com
            Also, my first google search also provided a link for a free download of the entire service manual for this old beast. Sorry, I'm in a bit of a mood today
            • ibrahim
              • Mar 2011
              • 6
              Re: Laser Unit
              no laser unit is same in 1045 and 2045
              • sakura
                • 132
                Re: Laser Unit
                How come it's the same if part numbers are different? Please clarify you "no it's the same". Have you ever swapped this two units?
                • teebee1234
                  • Jul 2008
                  • 1670
                  Re: Laser Unit
                  No, you cannot swap the laser between any of the models (1035/1045/2035/2045). But the part number is correct for the unit. Also, as Neergish stated, check the front door interlocks as the contacts can become corroded and laser 5v safety voltage from passing.
                  [Symptom]
                  SC 322 error is displayed randomly or permanently. Cover Open indications and image distortion may also occur.
                  [Cause]
                  Interlock switches for the front or side cover may have become dirty internally causing open or high resistance circuits.
                  [Action]
                  Replace the switches as a set [1204 2521] (Item 108) and [1204 2529] (Item 109).
                  • ronald2020
                    • May 2009
                    • 31
                    Hi you all!
                    To those of us that are still running these old beasts (actually good machines) especially the 2035/2045 3035/3045 in connection with sc322 I've found beside the usual fixes that everyone knows and last ditch effort is to change the laser unit, hold up try this first. Remove the LD unit get yourself a nice slim paint brush that can fit in the hole were it emits the laser (on the LD unit just in case you getting confused), refit then run sp mode sp2109-8 then 2109-3 then 2109-4 and you good to go. Spent a bit of cash replacing laser units till I decided to get to the bottom of this problem never replaced another unit since then and oh just make sure you keep it running clean as much as possible replace your seal if it's worn out on the dev unit to lessen toner spill between the drum unit and dev tank. When toner gets into the LD unit that is when you get the laser unit errors and remember to clean out the laser unit including laser sync board.
                    Hope this helps...
