RICOH SP8100dn and RICOH AFICIO 551
  • orlandoxp86
    • Jun 2025
    RICOH SP8100dn ( Before I Memory Clear the printer is normal but now all print Misfeed paper )
    RICOH AFICIO 551 ( I did Memory Clear the printer is normal but now all print Misfeed paper ) but this stuck on HOT ROLLER I changed UPPER FUSER ROLLER
    now stuck
    I have the Service Manual for the both
    please help me pc.junior.1884@msn.com
    thanks
  • Jomama46
    • 2900
    Re: RICOH SP8100dn and RICOH AFICIO 551
    So you cleared the memory on both? why? That is a last resort. What paper sizes are showing on the display? Did you reinput the non-defaults from the birth certificate. Did you reinput the destination code?
    sigpic
    A+; Network +; PDI+
    • orlandoxp86
      sp8100 error sc329 unfortunately yes I thought it would solve for the both
      but now I don;t know how can solve this
      • Jomama46
        • 2900
        call a tech, you're screwed
        sigpic
        A+; Network +; PDI+
        • mikadonovan
          • May 2008
          • 2931
          Could be you, dude. How far is Richmond from Fairfax?
          NEVER ASSUME ANYTHING
          • orlandoxp86
            1 hour 46 mins / 100.56 miles
            • sandmanmac
              • 3979
              Like Jomama Says... You're in trouble.
              If you have the manual. You should have noticed and paid attention to the text next to SP5-801 that says clearly in bold text: "Normally, this SP mode should not be used....".
              • orlandoxp86
                now what I have to do?
                one tech que be solve ?
                where to find?
                • Jomama46
                  • 2900
                  ..and why would you do it to both machines? I can only guess it has to do with meters.
                  sigpic
                  A+; Network +; PDI+
                  • Jomama46
                    • 2900
                    1. Reload the non-defaults from the birth certificate or the SMC you ran before you cleared the memory.
                    2. Run the SP to realign the laser.
                    3. "Get a haircut and get a real job" G. Throughogood.
                    sigpic
                    A+; Network +; PDI+
                    • sandmanmac
                      • 3979
                      Haha...Nice!
                      • orlandoxp86
                        I followed the manual but still not work
                        Service Program Mode Tables
                        • Jomama46
                          • 2900
                          call a tech
                          sigpic
                          A+; Network +; PDI+
                          • orlandoxp86
                            call a tech
                            do you know a tech in RICHMOND
                            • Jomama46
                              • 2900
                              No, but Google does.
                              sigpic
                              A+; Network +; PDI+
