RICOH MF3045 cannot install this software.helpppppp
  • stupidkiller
    • Oct 2011
    • 57
    i got one unit RICOH MF3045
    but i got this message [ This software already been installed on another machine.Cannot install this software ] keep blinking when i on the machine
    anyone facing this same problem ?
  • mikadonovan
    • May 2008
    • 2931
    Re: RICOH MF3045 cannot install this software.helpppppp
    What are you trying to install? PS3 supposedly can only be installed on one machine. What card is in the slot?
    NEVER ASSUME ANYTHING
    • Gift
      • Mar 2011
      • 2459
      Extended feature - isn't that for machines with java options? IIRC the A3045 doesn't offer this feature.
      Still I'd also say this seems related to the PS3 option. Simply check if a PS3 card is installed, remove it and power the machine on - if the error is gone, the PS3 option is probably faulty.
      • mikadonovan
        • May 2008
        • 2931
        Correction made
        • mikadonovan
          • May 2008
          • 2931
          Ooops, another correction made, dammit
          • stupidkiller
            • Oct 2011
            • 57
            i dint install any ps3,i only have 1 SD card which is "3045 printer & scanner" inside my slot 1 that so,slot 2 & 3 is empty
            any others way to remove this sign ?
            • sakura
              • 132
              Try to print a configuration page out of a machine and see if there is any mentioning about Postscript3 installed. PostScript doesn't allow you to merge itself to any other SD. Instead you can merge other apps into PS.
              Seems like your machine is missing something it had before and now every time you boot it up it is "looking" for it but can not find.
              Did you try to update a firmware?
              • stupidkiller
                • Oct 2011
                • 57
                ok i haved print all the configuration and i haved read it all and i dint saw anything mention about ps3
                i already update the firmware to the latest but it seems the same
                i haved replace the SD card with another same SD card also can not
                the only way to avoid this message is i remove the SD card from slot 1 then the message will disappear
                but i need the printer and scanner
                any idea~~~~thanks for the help ya~~~
                • Gift
                  • Mar 2011
                  • 2459
                  It's strange - have you tried backing up the nv ram data on sd card (still you should print a set of smc lists) and perform a memory all clear?
                  • stupidkiller
                    • Oct 2011
                    • 57
                    yes i haved done it with memory clear all and the message still appear
                    i got 2 unit of 3045 with this same problem
                    headache.......
                    • fbkhan3
                      • May 2012
                      • 421
                      What if you replace the DIMM or did you try formatting the Hard Disk ?It might sound stupid if i ask but are you sure about printer/scanner slot?
                      • stupidkiller
                        • Oct 2011
                        • 57
                        printer & scanner is slot 1
                        i dont think DIMM will cause this
                        but thanks u anyway =)
                        • Shadow1
                          • Sep 2008
                          • 1642
                          Print/Scan will not run in the base memory on this machine - an additional memory DIMM is required. I don't have my manuals within easy reach right now, but I think you need 384Mb.
                          73 DE W5SSJ
