Hi all need help.
Aficio3030 with print and scan type3030 sd card, but suddenly the print function missing and try to change another sd card with print and scan type3030,but still the print function missing and scan function are available.
Found out another problem was the IP address cannot change to new ip,onces off and on the power the IP adress go back the the old.Is controller defective?
Hope someone will shed some light on this problem.
Thank you in advance.
