Easy scanning question, probably
  • mikadonovan
    • May 2008
    • 2931
    Hey, All. I have a MPC2500 hooked up on a simple network. Machine and 2 computers plugged into the internet modem, the other 3 computers use the wireless. Printing and scanning (to folder) work great. However, on the display it still says "updating destination list failed, check delivery server version" How do I get rid of that indication?
    NEVER ASSUME ANYTHING
  • Gift
    • Mar 2011
    • 2444
    Re: Easy scanning question, probably
    You only need a delivery server configuration if you use the scanrouter software. Otherwise you should remove this configuration (I think you just need to remove the IP adress of the delivery server). I don't know the exact steps without a machine in front of me but it should be easy to figure out.
    • johnyb
      • Feb 2011
      • 167
      I think there is a setting in user tools, also in service mode SP 5845.
      thanks
      • kyrenecopy
        • Apr 2012
        • 205
        UNder system settings, file transfer, turn off delivery option
        Testing 1-2-3, testing, testing. Is this thing on?
        • sandmanmac
          • 3964
          x 2 on this
          Delivery option must be "on" when using Scanrouter, but "off" otherwise
          • mikadonovan
            • May 2008
            • 2931
            I'll do that. Thanks, guys.
