Equitrac and HID Card enrolling
  • ferastec
    • Jun 2009
    • 107
    Dear Guys
    I have done equitrac office installation, now i will have to assign the users HID card ID to their PIN number in Equitrac user profile, but we do have 800 users +, to add the ID number manually it will be nightmare, can equitrac do card enrolling like other application ( Ringdell, my Q Extraa...)
    Regards
    Feras
  • ferastec
    • Jun 2009
    • 107
    Re: Equitrac and HID Card enrolling
    hi guys, i have got the solution
    Prompt for
    Secondary PIN
    option is set to Only with keyboard login or AlwaysConfiguration > Security and authentication > User
    authentication
    2-Select the Auto-register primary PINs checkbox from the Authentication options section.
    Optionally, you can select Register as alternate PIN to record the PIN as the alternate PIN instead of
    the primary PIN. When Register as alternate PIN is enabled, the user can also login with a valid
    primary PIN and secondary PIN (if enabled) to complete registration.
    3-Click OK to save the changes.
    The next time the user swipes the card, their account information is automatically associated with the
    card, and they can login without manually entering their user credential
