Ricoh RW240 code-SC541-01 !!
  • sweet.persona
    Engineer
    • Nov 2009
    • 414
    please i have this err SC541-01 in ricoh , what mean this err and how to entre in mode save to reset it!! tha,k u in advance
    A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
    DAMENE ABDEL AZIZ
    DJELFA
  • JustManuals
    • Jan 2006
    • 9838
    Re: Ricoh RW240 code-SC541-01 !!
    Paul@justmanuals.com
    • jdzr
      • 125
      Fusing Thermistor Error 1
      The measured temperatureof the hot roller stayedbelow 7oC (44.6oF) for 60seconds after the machinewas switched on.-or-
      During machine operationthe hot roller temperaturefell to and stayed at 7oC(44.6oF) for 40 seconds.
      Make sure that the thermistor is setcorrectly.
      Make sure that the thermistor cable isconnected.
      Replace the thermistor.
      • sweet.persona
        Engineer
        • Nov 2009
        • 414
        thank you dear friend JDZR i have ckecked M thermistor and the connextion Between M T and DC all is corectly but nothing !!
        i think this machine Need for reseting can u tell me how to entre in MODE SAVE to clear it!
        thank u in advance.
        DAMENE ABDEL AZIZ
        DJELFA
        • jdzr
          • 125
          With all of the questions and problems you are having on this machine I really think you should purchase a service manual for this machine. I do not know of anyone who can service this machine without a manual. I regards to your problem fuser error codes are usually caused by some reason they do not just go away, but here is the reset procedure from the manual:
          Fusing unit SCs shown on the operationpanel. The machine is disabled. The usercannot reset the SC.Go into the SP mode. Set the main
          power switch to .off. then to .on
          If you do not know how to get into service mode you will definitely need a manual. If you are not familiar with this machine you can mess up to many things in service mode without a manual to help you through the adjustments and reset.
          Good Luck
