Ricoh MP5500 duplex jams at B2 gate
  • Old Crow
    • Aug 2011
    • 201
    [Jamming] Ricoh MP5500 duplex jams at B2 gate
    This problem is kicking my butt and causing me to pull what little is left of my hair out! Machine has only 160k on it. Only, but always, jams on duplex. Happens from all drawers. Always stops at reg. and kicks down B2 gate. Many times the rear side of the paper is folded over. Seems like should be obvious problem but damned if I can figure out.
    Tried whole different duplex unit with exact results. Pulled reg. section out under dev. unit. Cleaned all sensors, removed, ck'd and cleaned guide plates and mylars. The bottom mylar gets pushed behind top Mylar. Don't know if this is what's catching paper or is result of the jam. If running multiple duplex copies there are usually two or three sheets stuck there, at B2 gate.
    Also checked gate and plates that guide paper into duplex unit for burrs, all seem ok. Gotta go back again tomorrow(today) and try again. Not sure what's next. Any ideas much appreciated as I have three impatient women expecting me to fix this #%*@ machine!!!
  • TonerMunkeh
    Professional Moron
    • 3869
    Re: Ricoh MP5500 duplex jams at B2 gate
    Where's the machine registering the jam on the SMC?
    Hit it.
    • Old Crow
      • Aug 2011
      • 201
      I checked that at one point and forgot to write it down but I think in the jam location SP it was a "14" or "16" jam. Sorry, I don't remember for sure.
      • Old Crow
        • Aug 2011
        • 201
        I just found my notes, they are 7-504-13 jams.
        • Bantams
          • Jun 2012
          • 603
          Thats the Registration Sensor
          Have you removed the developer unit and then imediately below where it was cleaned the registration sensor one screw removes it and the bracket its mounted on its usually covered in paper dust
          • fbkhan3
            • May 2012
            • 421
            yesterday i had the Exact same issue with 2060, 3 sheets stuck every time under registration in duplex mode after 10 or 15 copies,Machine is running @ 5 million,Mylar seal was worn out,cleaned the 2 sensors,gear with one sided bearing in at rear end of registration unit,also replaced upper Mylar seal, it's running like a dog,no more jams. as you mentioned copy volume is just 160K so it can't be Mylar either it's sensors because sometimes paper dust makes them blind or something stuck in paper path,Also take out the paper feed units and clean them,
            • Old Crow
              • Aug 2011
              • 201
              Yes, cleaned the sensor mentioned, cleaned reg. rollers removed plates to look for a label, etc. Only happens on duplex so thinking it's not feed units or reg. unit?
              • Old Crow
                • Aug 2011
                • 201
                Today I replaced the inverter unit and the entire unit under the dev unit which includes the registration rollers, mylars etc. No help. Another symptom that it is doing is the reg.rollers "lock up" after jamming at B2 gate. tried replacing the registration motor and driver board, no help. out of ideas, any more help much appreciated. thanks.
                • vargue
                  • Oct 2011
                  • 404
                  you replaced all machine hhhhhhhhhhha check out registration clutch i faced this problem before.replace and tell me what happend
                  • fbkhan3
                    • May 2012
                    • 421
                    Luckily there ain't no registration clutch in these machines,and he already replaced registration motor and driver board,
                    • vargue
                      • Oct 2011
                      • 404
                      look my friend this machine has magnetic clutch and that is part number AX20 0277 search for it.
                      • fbkhan3
                        • May 2012
                        • 421
                        Exactly,but that clutch belongs to bypass feed,not registraton.
                        cheers
                        • fbkhan3
                          • May 2012
                          • 421
                          Exactly,but that clutch belongs to bypass feed,not registration.
                          cheers
                          • vargue
                            • Oct 2011
                            • 404
                            yes you are right i confused sorry
                            • jonezy999
                              just one copy??
                              • Feb 2010
                              • 952
                              I hate to sound like tech support, but, is it running the latest firmware? These things were riddled with bugs from production.
                              I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
