I need to replace an AF2018 BICU board (B1215101) that has been physically damaged. Problem is that the local parts supplier only has the newer K-C2.5 board (B2595101), and it takes months to get stock in from where we are.
Would anyone know if the two boards are interchangeable. I have had no problems using parts from newer series, even the Parisian on the older K-C machines, but for the BICU I need to be sure.
