did any one have power supply diagram or data sheet .power supply blow up i determined burned component but I'm still need p.s.u diagram.please help
power supply issue 2035
Tags: None
Re: power supply issue 2035
If you know which components are bad (I assume they're burnt) give us the component number written on the board and we may be able to take a look next time we poke our head inside one of those machines and read the values / chip number, etc.73 DE W5SSJComment
there is a components list at the back of the parts manual for the boards - good luck working it out and if you can get the parts due to the age.Comment
