Attached are the sample photocopies from the machine.In picture (1a) you will notice that there are dotted lines.That is the photocopy before I start troubleshooting the machine.I cleaned all the optical elements but still no luck.So I tried to reseat the connectors in the sensor board unit. When I switch on the machine and make a photocopy the output is totally poor as shown in picture (2a).Any ideas on this problem?Is it in a sensor board unit?The machine has a total counter of 383454 copies.Print out of the counter list is fine and the machine is just a basic copier.
