Just looking for the description of an SP from the manual
  • rthonpm
    • Aug 2007
    • 2852
    I'm helping a fellow tech remotely with an MP 7001, but they're not sure what they're looking at with a specific SP. It's Special SP 5-420. I don't have the manuals in front of me right now. Can anyone tell me what the manual's description of that SP is?
    Thanks in advance
  • rsyarcia
    Hair Straightener Tech
    • 711
    Re: Just looking for the description of an SP from the manual
    5420 User Authentication
    These settings should be done with the System Administrator.
    Note: These functions are enabled only after the user access feature has been enabled.
    001 Copy
    Nobody is perfect..
    • Choro1dal
      • Jun 2008
      • 176
      SP 5-420 Enables or disables user authentication per device function. Once user authentication has been enabled in User Tools.
      (You may want to use basic authentication, only for copying and document server functions but not for scanning)
      5-420-001 Copier (0 On, 1 Off)
      5-420-011 Document Server
      5-420-031 Scanner
      5-420-041 Printer
      5-420-051/61/71 SDK 1/2/3
      • Llama God
        • Mar 2009
        • 1353
        What on earth is he trying to do?
        • Tonerbomb
          AutoMajical Resolutionist
          • Feb 2005
          • 2589
          carefull he could lock himself out......
          Mystic Crystal Revelations
          • zed255
            How'd ya manage that?
            • 1024
            These settings are for allowing access to functions when user authentication is enabled in user tools. As an example, I have clients who use windows authentication to log in and scan, but the other functions are not restricted. When the applicable SP is set to '1' the function will not be restricted by the user tools setting.
