Ricoh MP7500
  • earth81
    • Feb 2012
    • 2
    [Error Code] Ricoh MP7500
    Hi!
    SC220? What is this? The official MP7500 service manual say nothing!
  • teebee1234
    • Jul 2008
    • 1670
    Re: Ricoh MP7500
    It's in there, but you were probably looking at the B064 section. The B140/B246/D052 is further down in the manual, which has this.....
    220 Laser synchronization detection error
    The 1st laser synchronization detection
    unit could not detect the line
    synchronization signal (DETP0) within
    500 ms while the polygon mirror motor
    was operating at normal speed.
    NOTE
    : The unit polls for the signal
    every 50 ms. This SC is issued after the
    10th attempt fails to detect the signal.
    B246/D052
    • earth81
      • Feb 2012
      • 2
      So many thanks for your help
      • Llama God
        • Mar 2009
        • 1353
        Re: Ricoh MP7500
        Originally posted by earth81
        Hi!
        It's usually the laser sync detector board (accessed from the right hand side of the machine, above the bypass behind 2 fans above the dev unit) or the laser diode unit, or the polygon mirror motor. I've had all three, unfortunately.
        • dooman
          Re: Ricoh MP7500
          SC220? What is this?I want the official MP7500 service manual
          • Zoran
            • 46
            Re: Ricoh MP7500
            Replace laser diode from aficio 1060 to mp 5500 6500...
