Ricoh 1022 won't scan to PDF
  • copyaction
    • Oct 2007
    • 991
    I know, real old, scanrouter no longer supported...
    At any rate in the scanrouter settings it is set to "multi page pdf" but the scans are coming in as tiff files.
    I looked at some recent scans and as of last Monday they were all saved as PDF files, as of today they are being saved as TIFF.
    Any ideas?
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    Re: Ricoh 1022 won't scan to PDF
    Resolution set too high?
    Maybe bad RAM?
    • sandmanmac
      • 3981
      Strange.
      It's probably just some sort of 'glitch' in the scanner. I'd do a memory clear on the scanner (only), then remove and add the I/O device in Scanrouter program.
      Note: I think the 'delivery option' will need to be turned "on" again after the memory clear
      • ccchuah
        • Mar 2009
        • 155
        Do all the user having the same problem ? Why not open up the destination setting to check whether someone have change the format, or try to create a new destination for pdf to test.
        • teebee1234
          • Jul 2008
          • 1670
          You are probably trying to scan in Grayscale, which is considered "photographic" (being an 8 bit image) and can only scan as a jpeg/tiff. The same thing will occur on standard SMB scanning to folder or email with our newer devices. If it is, change it to text or text/photo.
          • Tonerbomb
            AutoMajical Resolutionist
            • Feb 2005
            • 2589
            X2 !!!!
            Mystic Crystal Revelations
            • copyaction
              • Oct 2007
              • 991
              Thought of that but it is set to text.
              • oldschool
                • Mar 2007
                • 245
                I don't know much about this copier but I know to create a PDF you need postscript. Doesn't this model have an optional postscript card?
                Jamex Tech Support: Saving the world one phone call at a time.
                • copyaction
                  • Oct 2007
                  • 991
                  I think that is only for printing. It has been working fine for over 5 years prior to this.
                  • sandmanmac
                    • 3981
                    I'm afraid that's completely untrue and inapplicable to this problem
                    • Bantams
                      • Jun 2012
                      • 603
                      Someones Been messing about with the settings on the PC where the scans are going too its not a Copier related Problem.
