I have a question about Black & White Ricoh scanners. Would it be possible to scan documents with the scanner and then print them on a 1200dpi laser printer and get the same quality results as if I copied and printed them on a 1200dpi Ricoh copier like a 1075? About a year ago I went to a Ricoh dealer and had them demo a scanner and they scanned some documents into a pdf format and the results when printed, especially with graphics, was disappointing. I wonder if there is another format to scan the document into that would produce true 1200dpi results when printed on a laser printer. I print a lot of documents with graphics in them and really need a 1200dpi machine.
I understand that Ricoh has a proprietary format that its copiers use. I am intrigued by this format because I can scan a 200 page document with lots of graphics into a Savin 8090 and still have 95%+ hard drive capacity left. If I scanned these same documents on my Epson flatbed scanner in 1200dpi I would probably fill up a 200Gig hard drive. I would use enormous amounts of storage space.
Any comment or ideas would be appreciated.
