Command Wokstation ERROR 3071
  • elladar
    [Error Code] Command Wokstation ERROR 3071
    Hello, i have two threats i need to attend, by one hand i own a Ricoh Aficio 6513 color copier. Ive installed all the drivers and postcript 3 in Windows XP SP3 as well the printer. The problems gets me when after having installed succesfully the Command Workstation 5.3.0.57 it searches the fiery, locate it and conects. Untill there is all ok, but suddenly the program shows a ERROR 3071 code. Ive printed the sample copy but cant do anything else. What can i do?
    By the other hand the problem is also with a Ricoh copier, Aficio 650 this time. The matter is about the density of the toner supply mode, ive been working with it since last week and the density of the black toner was very good. Now it prints a little darker, ive entered in sp mode 2209 and setup the tonner suply rate in 900 mg/s. Originally it was in 650 mg/s. That have should fix the problem but it didnt, still a little darker copy but always a good quality. How can i setup the copier to get a propper toner density?
    Im from Argentina,
    Thanks for the help.
  • azehnali
    • Nov 2009
    • 679
    Re: Command Wokstation ERROR 3071
    gig you find a solution for the error 3071?
    I have the same problem
