replace NVRAM MPC 6501
  • tullio
    • Feb 2012
    • 268
    replace NVRAM MPC 2800
    How to replace new NVRAM MPC 6501 ? and how to download from old NVRAM ?
  • Jomama46
    • 2900
    Re: replace NVRAM MPC 6501
    You arn't asking for troubleshooting advice and I don't normally recommend this but what the hey, you sound like a competent person. Run 5844 to upload the data , remove the old nvram, insert the new one and clear with 5801. then run 5845 to download to the new nvram.
    sigpic
    A+; Network +; PDI+
    • turbojetboy
      • Aug 2009
      • 279
      I have to ask, why do you need to do this? It is always a LAST resort, especially on this model. You can expect all sorts of trouble with false toner out messages and devs going wrong etc etc etc.
      • JustManuals
        • Jan 2006
        • 9919
        Paul@justmanuals.com
        • nmfaxman
          • 1705
          Just so you know.......
          Replacing Nvram and moving the data won't reset the electronic counter.
          • tullio
            • Feb 2012
            • 268
            replaced all PCB boards., eeprom. same problem.
            Tandem Tray error on the display.
            • sakura
              • 134
              As mentioned before - NVRAM replacement is the last resort. Check out all harnesses for any damage, electrical connections between boards (controllers) may cause weird issues. Also it's ALWAYS good to have a spare machine you could "borrow" parts from and see if it's going to make any difference...
              P.S. DO NOT try to use "used" NVRAM though
              • Llama God
                • Mar 2009
                • 1353
                [ATTACH=CONFIG]16623[/ATTACH][ATTACH=CONFIG]16624[/ATTACH]
                Well, these are worse than useless.
                This is not an NVRAM issue, it's a harness/connector fault (at a guess.)
