mpc3500
  • xordi69
    • Jun 2010
    • 200
    mpc3500
    hello. I have this trouble in a MPC3500.
    I have tried all type of paper that have machine, the trouble is in copy and printing, but only with a3 paper, 120gr in second try.
    fuser guides are cleaned and have a newfuser belt.
    Thanks in advance
    Xordi
    mpc3500.pdf
  • copiman
    • Sep 2011
    • 861
    Re: mpc3500
    Have you tried stopping it before fusing to see if the problem is prior to fusing?
    • xordi69
      • Jun 2010
      • 200
      Re: mpc3500
      I'm not sure, short distance between the fuser and transfer. lines makes the fuser peroentonces I have a problem of "traction", maybe record or output unit? A4 everything perfect.
      excuse my english...google translator
      • fbkhan3
        • May 2012
        • 421
        Re: mpc3500
        Are you sure it's the same with Print and copy A3?
        if problem remains with only A3 copy then you need to be looking in to scanner towards A3 ,just run a scanner free run with lamp off to check smooth run.
        Most of time Bad ITb(image transfer belt)can cause such image shifting,bad PCU or a laser shutter,
        No doubt you gonna get allot better and to the point hints from senior members,
        good luck
        • xordi69
          • Jun 2010
          • 200
          Re: mpc3500
          good luck
          sure in print and copy, no scanner problem, and trouble only in a3, in a4 all right, then i discard pcu and laser. itb runs finein a4...
          thanks
          • JustManuals
            • Jan 2006
            • 9838
            Re: mpc3500
            Paul@justmanuals.com
            • Llama God
              • Mar 2009
              • 1353
              Re: mpc3500
              What are the PM counters like?
              • xordi69
                • Jun 2010
                • 200
                Re: mpc3500
                90k in color, 60k in black, but I think is not a consumables troble...
                thanks
                • Llama God
                  • Mar 2009
                  • 1353
                  Re: mpc3500
                  So a combined 150k? It's due all sorts then, start with them.
                  • Llama God
                    • Mar 2009
                    • 1353
                    Re: mpc3500
                    But to clarify:
                    2 x colour PCUs (80k)
                    Transfer cleaning station (160k)
                    Transfer separation roller (160k)
                    Full fuser rebuild, especially the oil roller (160k)
                    • engineers
                      • 51
                      Re: mpc3500
                      I had this issue same as you, on a MPC4500. On A3 being run through tray 4 on the Thick 1 setting.
                      If your lucky and can get away with changing to the middle thick setting you will be fine, if like me you have no choice but to stay at thick 1 then:
                      I cured by adjusting the fuser motor speed (SP1-801) sorry can't remember exactly what i set from and to what.
                      Seems that the paper is fed too fast into the fuser causing the paper to bend and scuff across the area opposite to the fuser entrance guide.
                      • xordi69
                        • Jun 2010
                        • 200
                        Re: mpc3500
                        I also think is a speed trouble, thanks, I'll will try it early and will tell you if it works fine
                        • Herrmann
                          • Jan 2006
                          • 792
                          Re: mpc3500
                          Have a look at the Fuser entry, there is a plastic part that guides the paper. Remove it and clean it thoroughly, then reattach and make sure, that you mount it in the lowest position possible.
                          If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
                          • banginbishop
                            grumpy old git
                            • Oct 2007
                            • 894
                            Re: mpc3500
                            what toner is it oem or generic? generic causes all sorts of problems especially on coated/glossy paper. As the god that is LLama has stated you have to pm these machines.
                            Incontinentia Buttocks
                            • Ramón
                              • Mar 2011
                              • 26
                              Re: mpc3500
                              Hello George: You're going to fix by replacing the roller PTR.
