Aficio 2232c Image is offset
  • zflash7
    • Jun 2012
    • 39
    Hi, is there a code to correct the set of the printing page. it is not set right on the page. It lifts to the top. Can I make the adj. without the C4 test pattern? Or where can I download the C-4 chart?
    Via the codes?
    Tks
    Paul
  • turbojetboy
    • Aug 2009
    • 279
    Re: Aficio 2232c Image is offset
    Via the codes?
    Tks
    Paul
    Does the machine complete the "auto registration" ok in the user tools? If not you have some work to do.
    • zflash7
      • Jun 2012
      • 39
      The registration, adjusts according to the skew. I have the line adjustment procedure it looks like fun.
      I just printed 50 off and its still skewed. mainly on the B&W print the colour is ok.
      • turbojetboy
        • Aug 2009
        • 279
        Can you post a sample. Has the machine had a NVRAM clear, if so you will need to re-enter all non default data. If you are not experienced on this model then playing around with the line position adjustments will drive you nuts - and waste hours of time. I personally believe that until you can get the machine to successfully run its auto reg setup you are wasting your time.
        • zflash7
          • Jun 2012
          • 39
          OK. I will do that first.
          tks.
          nuts I dont need.
