Ricoh 1515 MF sc320 and 121 codes
  • nmfaxman
    • 1702
    Turn on machine and I get stationary jam code, then sc 121, then sc 320.
    Replaced laser, BICU and power supply.
    Isolated DF, fax board, HVT and all sensors.
    I can turn on all 24v motors through service mode.
    I have 5v and 24v out of power supply, but the scanner home position sensor reads 1.2 volts on 5v line.
  • vargue
    • Oct 2011
    • 404
    Re: Ricoh 1515 MF sc320 and 121 codes
    this sc320 and sc322 in small models due to hopper toner unit don't set correctly. be sure that unit set on properly .and sc121 what is your notification on machine. lamp/lamp stabilizer/ hp sensor/scanner wire/...
    • nmfaxman
      • 1702
      Turned out to be 2 BICU boards with same problem.
      What are the odds?
      • worksmart
        • May 2010
        • 16
        Yep... the same situation here as well.... replaced BICU, Controller. No progress...
        When the machine is turned on - Please wait appears for 10sec the Jam indicator turns ON (Open the right cover - and remove the jam, location A), then after sometime approx 10sec SC121 appears...
        waiting for any feedback...
        Thanking you all ....
        • nmfaxman
          • 1702
          Found that one of the mirrors was backward.
          • Dumus
            • Feb 2010
            • 79
            Or,
            SC121 : clean up the white tape under glass. (Between the original glass and glass of ARDF).
            • oswaldo160
              • Oct 2008
              • 69
              What is the solution?
              I have the same problem, first the jam code-sc121 and sc320.
              • sandmanmac
                • 3977
                Several solutions provided above. What have you tried?
                • oswaldo160
                  • Oct 2008
                  • 69
                  I changed the Laser Unit and the power supply unit. Now I am checking voltage in the BICU.
                  • nmfaxman
                    • 1702
                    Check the mirrors.
                    If you touch the surface with a pen the image makes contact.
                    If it looks like it is at an angle, then it is backward.
                    • oswaldo160
                      • Oct 2008
                      • 69
                      Check the mirrors.
                      I checked the mirrors. But the SC121 and SC320 continues
                      • dgressy
                        • Dec 2011
                        • 25
                        I whould like to fix the scannerinitialposition sensor in a mp c3000 becourse of the sc121 (shown as lucky scannermovement at start) - anybody here knowing where it is exactly ?
                        it feels like the sc121 comes more often when powering off every evening...
