MP2550 with SR790 Finishers
  • Solotime
    • 223
    We just received in 2 of these units and both are throwing SC792 codes. The finishers are hooked up and installed properly. Strange that both are doing this. Is there something on the setup that I am missing. Both are very good condition used machines with around 40K on them.
  • rthonpm
    • Aug 2007
    • 2852
    Re: MP2550 with SR790 Finishers
    I may be misremembering, but I think that the firmware for the finisher ROM had to be at a certain level for it to work with the newer generation machines.
    • Jomama46
      • 2900
      SC 792 Check accessory harness for possible short
      SC 792 Finisher Unit Error - Defective finisher harness
      SC 792 Finisher Unit Error - Defective finisher unit
      SC 792 Finisher unit error - Check/Replace Fuse 4 on PSU
      SC 792 Finisher Unit Error - Poor connection of finisher
      SC 792 Finisher Unit Error - remove bridge unit if no finisher installed
      SC 792 Finisher unit error: Check/Replace Fuse 4 on PSU
      SC 792 Finisher Unit Error: Defective finisher harness
      SC 792 Finisher Unit Error: Defective finisher unit
      SC 792 Finisher Unit Error: Poor connection of finisher
      sigpic
      A+; Network +; PDI+
      • Llama God
        • Mar 2009
        • 1353
        I think that I read this too, probably in a firmware download recently.
        • Bantams
          • Jun 2012
          • 603
          +1 Firmware needs updating
          • Gary Bowen
            Bowdog
            • Mar 2008
            • 250
            Current version of firmware for the SR790 Finisher is v5.11. It is an EPROM so must be replaced on the Finisher Control PCB. The part number for the EPROM is B4085164.
            • Solotime
              • 223
              I will check to see if I can order this chip...not being a Ricoh dealer and all. So if this new firmware Eeprom is replaced that will resolve the error without having to apply any updates to the copier?
              Thanks again
              • SteveF
                Field Service Manager
                • Jul 2012
                • 49
                I seem to remember you need to check if it is a 790 a or b series...the a version wont work on the newer models
