Ricoh Aficio 1224C Error Code SC481
  • inform
    • Aug 2025
    Hi,
    I have a Ricoh Aficio 1224C printer with the Error Code SC481.
    Can somebody please explain what this is? -What should I do?
    Is it possible to get into the service menu over a button combination and delete the code?
    THANK YOU.
  • hosennet
    • Mar 2007
    • 145
    • inform
      Hi hosennet,
      Thanks for the reply.
      So we need a technician to solve the problem? No chance to fix it ourself?
      Regards
      • inform
        ps. The main motor is running, I hear it.
        On lucky days the error dont comes and the printer works fine.
        Or the error is there, we switch the printer off and then the error is away.
        Regards
        • Cipher
          It's not easy being green
          • May 2006
          • 1309
          A ITB belt inspection / repair would be a job for tech.
          Or you could just order a new PCU which would fix the problem.
          • inform
            Thank you guys for the fast answers!
            • inform
              If someone has a service manual for a Ricoh Aficio 1224C, please contact me.
              I will donate a few bucks with PayPal.
              Thanks and regards
