MPC 7500 w-sc870
  • T911
    • Jun 2007
    • 628
    MPC 7500 w-sc870
    cant get scanning duplex or sorting back. replaced the hdd but it fails when i format it. do i need to replace both hdd's then do 5846-50 and 5832.
  • Bantams
    • Jun 2012
    • 603
    Re: MPC 7500 w-sc870
    I Believe the HDDs need to be replaced as a set.
    Did you try Formating before replacing the one you replaced?
    • T911
      • Jun 2007
      • 628
      Originally posted by Bantams
      I Believe the HDDs need to be replaced as a set.Did you try Formating before replacing the one you replaced?
      yes i tried the format with the orignal in the machine first it failed then rescheduled for one hdd. i'll try going back with both.
      • ricoh
        • Oct 2010
        • 14
        Hi T911
        Due to these devices using a unique proprietary RAID format, all HDD's must be replaced at the same time.
        Enjoy.
        • T911
          • Jun 2007
          • 628
          Thanks guys, i replaced both hdd's it tripped a 925 and did a 5832-11, all good. Thanks again.
