LD130C/MP C300SR
  • ucinn
    • Jun 2009
    • 383
    LD130C/MP C300SR
    I have an out of box failure..sc202... replaced laser unit, BCU, & IPU to no avail. Any ideas? Can't find a point to point anywhere out there. Is there one available for this model?
  • tcs04
    FORMER Techie
    • 1183
    Re: LD130C/MP C300SR
    Who can guess what the next reply will be??
    • fbkhan3
      • May 2012
      • 421
      I do have the P 2 P.send me your ID, Dont know why not able to attach,keep asking me login ,, already m! Feel free to PM me!
      • ucinn
        • Jun 2009
        • 383
        I found the p2p..thanks for the help..I see they aren't included in the service manual anymore...nice.
        • fbkhan3
          • May 2012
          • 421
          Yep it took me 7 minutes on Tessa to figure it out! anyways good luck!
          • ucinn
            • Jun 2009
            • 383
            It's solved. although the blown fuse conditions in the service manual doesn't show this, but if the top 10A fuse on the power supply is blown, it will cause an SC202.
            • fbkhan3
              • May 2012
              • 421
              wola! Great ,you got it. But was that a bad line filter behind that or something else?
              • ucinn
                • Jun 2009
                • 383
                One of our set up techs pinched a wire while installing the fax option. It took out the IPU which was giving an SC120...wasn't seeing the home position sensor, and the fuse which was causing the SC202.
                • tcs04
                  FORMER Techie
                  • 1183
                  Always the best ones!
