MC4502 ( memory faxing not working)
  • Boonboon
    • Aug 2025
    [Misc] MC4502 ( memory faxing not working)
    I am able to fax mannually, however when it comes to memory faxing, it doesn't work. I have downloaded the new firmware, GWFCU but it is still not working. How can I overcome this problem?
  • Copierdocisleofman
    Senior Technician
    • Aug 2009
    • 86
    Re: MC4502 ( memory faxing not working)
    what version is the firmware?
    • Boonboon
      My firmware version is GWFCU 3.5, D6435570H. I have changed the FCU PCB.
      • Rusdiman
        Hi, I have the same problem as you. So, changing the fcu pcb solved the issue? Update: I have just done the following steps that you said but it is still not working, anymore advice? Thanks
        • SteveF
          Field Service Manager
          • Jul 2012
          • 49
          hello
          you might want to try resetting the fax system and see if that gets it working
          • revenent
            • Jun 2012
            • 5
            Very likely the customer is using some form of international budget call box for overseas faxing. I have encountered such a problem in the field whereby after the customer removes the budget box, both the incoming and outgoing faxes work normally. As for the budget box, customer will have to get the vendor in to fine tune the frequency in the budget box to suit the copier's DTMF signal.
