hi
I have a MPC 4500 the first problem i had was that is was not printing... i installed drivers etc.. even the ping to the machine was ok... but every print job failed...
then i thought it could be a authentication issue, so i switched it on and now i cannot log into the machine, even as admin (password blank) or supervisor (password blank)
is the only way to fix these issues done by replacing nvram? if so, even if i copied the setting onto a sd card, will i be able to log in?
thanks for your help!
Ron
Ron
