ricoh aficio 2075 sc990
  • salmandol
    • Mar 2009
    • 107
    hi all, sc 990 comes after 1 copy. replace all circuit boards, tested with working dr unit. could it be coming from laser unit. thanks in advance
  • banginbishop
    grumpy old git
    • Oct 2007
    • 894
    Re: ricoh aficio 2075 sc990
    sc990 is normally hdd/software errors
    taken from the af2090
    SC990: Software Performance Error 1
    Definition [B]
    An unexpected operation was encountered by the software.
    Possible Causes
    Software crash; reboot the machine
    Procedure 1
    If the HDDs have just been replaced, be sure to download the stamp data (SP
    5853).
    Procedure 2
    With SP5990 004 (SMC Report . Logging Data), print the most recent information
    for SC990. The SC990 information displays the file name, line number, and value.
    Report this information to your technical supervisor. For example:
    Function.c LINE: 123 VAL:0
    Incontinentia Buttocks
    • salmandol
      • Mar 2009
      • 107
      i tested machine from the by pass only and it works so i guess something in the lower feed section is the culprit...
      • vargue
        • Oct 2011
        • 404
        x2 that is not mechanical threat it's pertained to hdd or software sluggish.rarely happens in door switches
        • salmandol
          • Mar 2009
          • 107
          turned out to be the paper feed circuit board....
          • vargue
            • Oct 2011
            • 404
            are yo sure??????????????
            • JustManuals
              • Jan 2006
              • 9838
              http://www.justmanuals.com
              Paul@justmanuals.com
              • salmandol
                • Mar 2009
                • 107
                positive. i swapped back the old board and problem came back. weird huh?
                i have learned that problems are sometimes caused by the furthest thing related to the error code.
                thats why i like to check this forum cause you find solutions that are not in any manuals but by experience.
                • aref1369
                  • Nov 2014
                  • 11
                  hello
                  that is the td sensor is defective or dirty
                  you clean it and chek
