mpc4501 drum conversion
  • banginbishop
    grumpy old git
    • Oct 2007
    • 894
    have a solution for the above machine. all details to be released as soon as i have full details. I understand it will allow the black drums to be used in the colour locations.
    Incontinentia Buttocks
  • Bantams
    • Jun 2012
    • 603
    Re: mpc4501 drum conversion
    The MPC2500 black drum is the same as the Color drum except for the connector on the rear.
    To modify the MPC2800 Black drum to fit the color slot just cut away the small pin on the connector block and swap the 2 wires round nearest the gear on the connector that plugs into the dev units.
    But the MPC2500 BLK drum as the wires in the same place as the 2800 series color you just need to cut out the pin on the rear connector.
    • banginbishop
      grumpy old git
      • Oct 2007
      • 894
      mate - im not going to be rude to you but look at the title
      • Bantams
        • Jun 2012
        • 603
        Ooops Point taken must have miss read it as MPC4500 my bad Long day today.
        • banginbishop
          grumpy old git
          • Oct 2007
          • 894
          no probs 4501 has the big metal plate to stop it being used or so they thought!
          • Bantams
            • Jun 2012
            • 603
            Would be awesome if you figure this out.
            Do you know about the spc811 and 820 fusers fitting the mpc4500 and 5000s with changing the positions of the 2 pink wires on the connector plug?
            • Llama God
              • Mar 2009
              • 1353
              I know the answer to this.
              Buy some very strong cutters and cut the pin on the rear of the machine out so that it's flush with the top of the PCU's guide rail.
              That's what we've been doing anyway. Obviously Ricoh would take a dim view if they saw it!
              • Lagonda
                • Aug 2008
                • 1649
                The same solution can be used on the new MP C5502 range.
                • banginbishop
                  grumpy old git
                  • Oct 2007
                  • 894
                  bah humbug dont like the pair of you anymore
                  • Llama God
                    • Mar 2009
                    • 1353
                    I fart in your general direction. So-called English kurrrniggits!
