ricoh mp 4500 adf screwing with me
  • advcopy
    • Jun 2012
    • 25
    when making copies off of the adf the top of the page is lighter then it should be. also it "shifts" the image of the copy off center
    this does not happen when copied from of the glass
    anyone know how to help this
    thank you
  • advcopy
    • Jun 2012
    • 25
    Re: ricoh mp 4500 adf screwing with me
    also i forgot to add the slip glass has been cleaned, roller cleaned, after stdying the adf i seen nothing that would skew the copies alignment
    • Llama God
      • Mar 2009
      • 1353
      I don't suppose that you could attach a scanned sample?
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • AyJayAreDii
          • Jul 2010
          • 99
          try this... close the ARDF, put your hand on the back left corner of the ARFD and push down. take your hand of then take a copy.
          I had a colour c4500 (pretty much the same DF do this to me, we found that because they had decided to put the machine under some selfs, put a very slight twist on the hinge. you can see it but it adds pressure to the mechanism that lifts the DF when taking "bookcopys". so when opening and closing the df, it does not quite come down enough to put on even pressure. although it looks like it is flat down and straight, you should feel the df drop when you push the back left corner if this is the issue. If not the case, when you open the DF, the right hinge adjusts the skew screw. just unscrew it out of the small hole and put it into the elliptical hole hole just to the right (may have a cover over it) and adjust it in both directions to see if anything changes.
          Happy Hunting
          • advcopy
            • Jun 2012
            • 25
            wish i could the machince is out of town when i go see it ill bring a copy for ya
            • advcopy
              • Jun 2012
              • 25
              Happy Hunting
              thank thatgood advice ill give it a try
              • hawnrippa
                The Adf scanner lower entrance guide needs to be removed and the 4 mylars needs to be inspected. The mylars are probably bent or worn down, causing your Adf skew issue.
                • withnail
                  • 59
                  I had the same issue with a MP9001, light on the hinge side of the copy. The client had let the df open many times under its own spring pressure which had lifted the frame where the left hinge was screwed down, I removed the df and the plastic covers and hammered the frame flat again to cure this fault. I think you might find the same fault on your machine from what you've described.
                  • kannuki2
                    • Feb 2012
                    • 398
                    thank you
                    have you cleaned the scanner optics and xenon lamp? dust can cause this problem. is it shifting side to side direction? or just leading edge is shifted? raise the left scanner bar a little bit higher. also you can adjust the df right hinge loosen the screw and move it up or down for image shifts.
