Looking at the parts catalogs, both machines use a similar-looking BICU - part# B0825065 (for the 2035) vs. B1385065 for the 2045e. Couldn't find any other individual boards at a glance. Probably worth a shot.
Nic and Ram work if I believe, but the printer/scanner boards are most definatly different. You'll usually get a sc code when you put in an incompatible part.
