MPC4500 SC 553 Intermitant
  • Bantams
    • Jun 2012
    • 603
    Completely stuck on this one got a new fuser unit in it and still throws up SC553 at random intervals usually lasts a week or two before throwing up the same sc code when its first powered on in the morning.
    Any Ideas?
    all firmware is updated and Fuser unit is New.
  • Zeldaman
    • Mar 2011
    • 946
    Re: MPC4500 SC 553 Intermitant
    Hi there!
    Ricoh says IOB, PSU or fusing-unit. Had the same problem with a MPC 5000, same sc-code only in the morning. After changing the ih-board the problem was gone.
    Greetings...
    • Bantams
      • Jun 2012
      • 603
      Thanks will try IOB next.
      • AyJayAreDii
        • Jul 2010
        • 99
        Originally posted by Zeldaman
        Hi there!
        Greetings...
        I can recall this on a few machines, IH board i'm sure solved it. As stated above.
        • Bantams
          • Jun 2012
          • 603
          Ive Never Heard of a IH PCB before I assume thats the one Under the fuser fan right?
          • Llama God
            • Mar 2009
            • 1353
            Big beefy bastard behind the duplex.
            • Bantams
              • Jun 2012
              • 603
              • Llama God
                • Mar 2009
                • 1353
                Outstanding, we'll probably buy that bugger and get lumbered with the fault!
                • Bantams
                  • Jun 2012
                  • 603
                  You will if you work for Danwood
                  • Llama God
                    • Mar 2009
                    • 1353
                    I don't, thank fuck.
                    • pfinn10
                      • Jun 2010
                      • 46
                      Had something like this awhile back, Tried boards, new Fuser units etc. kept thinking had it fixed, kept coming back 1-2 weeks later. Ended up been fuser drive giving issue. changed motor, clean drive. problem went away.
