MPC 4000
  • Toner Man
    • Mar 2011
    • 56
    MPC 4000
    Two Issues:
    1. Skewing from all 4 trays on single-sided copies or print jobs-possible registration issue, not sure if it is a clutch issue or what
    2. 8x11 paper: 2nd page touches the first page at the bottom of the duplexer causing skewing and crumpling of the pages, 11x17 or 8x14 pages never skews or touch one another
    Could be a timing issue in that the first page should enter the mfp before the second page has a chance to touch it
  • banginbishop
    grumpy old git
    • Oct 2007
    • 894
    Re: MPC 4000
    skewing from bypass? remove the registration plate and check the mylar or any glue from the media being used as well. oh and firmware up to date?
    Incontinentia Buttocks
    • NeoMatrix
      Senior Tech.
      • 3513
      Re: MPC 4000
      What does the SMC report say ?
      SP 5994?
      Any problems with the Junction Gate sensor or Fuser Exit sensor counters ?
      • JustManuals
        • Jan 2006
        • 9838
        Re: MPC 4000
        Paul@justmanuals.com
        • Toner Man
          • Mar 2011
          • 56
          Not jamming from the bypass
          Good idea, to check the registration plate
          • Toner Man
            • Mar 2011
            • 56
            Haven't checked the SMC report yet, thanks for the reminder
            • tcs04
              FORMER Techie
              • 1183
              Re: MPC 4000
              Originally posted by Toner Man
              Two Issues:
              The registration sounds like the same issue we had on an MPC4500 recently. Went through the usual, bickle adjust etc with no success.
              Changed the green plastic bushes on the reg roller (The ones the springs hook onto) and the rubber reg roller, seems to have improved 95%. Am returning with the reg guide this week as a precaution, the mylar on the guide is worn.
              One of our guys told me he had an issue with "Crumpled paper, Z folding , Jams at fuser / exit". He found a cooked sensor "On the duplex door above the rear edge of the fuser" (?). Haven't seen the fault myself, but the previous tech had ordered guides / clutches etc and it didn't cure the problem. He swapped the sensor with one from an old paper feed station (Same part) and it cured the problem.
              • Toner Man
                • Mar 2011
                • 56
                Problem Resolved
                The driven roller on the fusing cover had a spring missing so the rollers were not engaging with the duplex guIde rollers. Good info on your behalf as well.
                • tcs04
                  FORMER Techie
                  • 1183
                  Re: Problem Resolved
                  mmmmmm...... feedback!
