smtp vs its actual ip - outgoing mail server problems
  • Dexor
    • 223
    Ricoh is notoriously stupid about changing the actual smtp server into its ip. It simply can't do it. I'm forced to use the actual ip address of the smtp server. The problem with it is that it does change over time, sometimes rapidly.
    Is there a way around it? We've been using smtp relay services but we are rapidly reaching our monthly limitation cap. What's the best way to setup outgoing mail server on ricoh?
  • rthonpm
    • Aug 2007
    • 2854
    Re: smtp vs its actual ip - outgoing mail server problems
    The issue generally isn't with the MFP, but with the latency of the DNS servers that the machine polls for names. Is the DNS you're using for the machine onsite, or off? Is there more than one DNS server listed for the machine to use?
    • Dexor
      • 223
      DNS is onsite, we have two, both programmed into the mfp (our office is where I do all my experimentation). I have never found any difference using/not using DNS. SMTP relay always works, uses port 80. But we are maxed out.
      • rthonpm
        • Aug 2007
        • 2854
        What model is the Ricoh? Does the SMTP server require SSL? If so, then there will always be issues as most Ricoh machines beyond the current models don't support it. Is the SMTP server using the standard port 25, or a different one? Any authentication required for access?
        • Llama God
          • Mar 2009
          • 1353
          Right, now, steady on there, of course using DNS makes a difference.
          It's worth using both on-site and external DNS servers for this. I believe, off the top of my head, that the machine can handle up to 3 so, to give it a fighting chance, put 3 in.
          In addition, program a WINS server address into the machine - this is quicker than a DNS server.
          Finally, when you say that you are "maxed out," what does that mean? No offence intended, but it's kind of gibberish.
          • Venom
            Technical/IT Support
            • Nov 2009
            • 765
            add in Google DNS servers 8.8.8.8 and 8.8.4.4
            IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
            • Llama God
              • Mar 2009
              • 1353
              Or OpenDNS' as follows:
              Predict and prevent attacks before they happen using our cloud-delivered enterprise security service. Protect any device, anywhere with OpenDNS.
              • TheOwl
                • Nov 2008
                • 1732
                What sort of mail server is it?
                Are you running Exchange or using a hosted mail server?
                • impetus73
                  • Mar 2012
                  • 75
                  One solution, is to set up your own local SMTP server, there are lots of free mail server programs out there. Set it up on the local server.
                  One example:
                  http://www.softstack.com/freesmtp.html
                  • Dexor
                    • 223
                    Ricoh MP C3500
                    can't do ssl on ricoh
                    auth is a must
                    smtp server name - must use actual IP address - always.
                    • Llama God
                      • Mar 2009
                      • 1353
                      Ricoh MP C3500
                      auth is a must
                      We consistently set up scan-to-email using the server name (eg relay.plus.net) and it works fine.
                      • Dexor
                        • 223
                        Originally posted by Llama God
                        Right, now, steady on there, of course using DNS makes a difference.It's worth using both on-site and external DNS servers for this. I believe, off the top of my head, that the machine can handle up to 3 so, to give it a fighting chance, put 3 in.In addition, program a WINS server address into the machine - this is quicker than a DNS server.Finally, when you say that you are "maxed out," what does that mean? No offence intended, but it's kind of gibberish.
                        Not always possible to get offsite DNS servers, and frequently wins server not being used.Having even all 3 DNS never made a difference in hundreds of clients, the ONLY diff was using SMTP relay. "Maxed out" was explained in my original post, we can only use it to certain limits of clients/emails per month - now clear?I'd love to use Google as SMTP but never been successful, neither was anyone else, judging from the posts. SSL looks like the culprit.
                        • Dexor
                          • 223
                          Ricoh MP C3500
                          auth is a must
                          ...and that's because you're using smtp relay? That's the only thing that works for me, but I still have to use IP address. Or customers non-web based email, which always works, but it's not always available.
                          • Dexor
                            • 223
                            Originally posted by Llama God:307445
                            Thx, will give it a go.
                            • Llama God
                              • Mar 2009
                              • 1353
                              We've developed a stand on scan-to-email which is as follows: if you don't have an exchange server, it won't work.
                              Now that hosted exchange is becoming more prevalent, we're having to use their ISP's mail server to relay traffic outbound. As the ISP trusts all outgoing traffic, relaying through their mail server isn't an issue (it doesn't need a specific connector setting up).
                              Having said that, we've never had a DNS issue with the server name vs IP address as you're describing. I reckon that either external DNS addresses or a WINS address will rectify this.
