Ricoh Aficio 2075 in "Plaease Waith" permanent
  • Fogonazo
    • Jul 2011
    • 15
    [Misc] Ricoh Aficio 2075 in "Plaease Waith" permanent
    Hello.
    I have the following problem with Ricoh Aficio 2075.
    Once the heating cycle the machine goes to "Ready", allows you to take one or even print multiple copies of a document "Document Server", but at the end goes: "Please Waith "and does not leave until that condition is turned off and back on.
    No specific fault code
    Initialize and format the memory and hard disk without getting changes.
  • fbkhan3
    • May 2012
    • 421
    Re: Ricoh Aficio 2075 in "Plaease Waith" permanent
    Go through mentioned above link,it should lead to the solution!
    • Fogonazo
      • Jul 2011
      • 15
      Thanks for your reply
      I'll try these suggestions
      • kyrenecopy
        • Apr 2012
        • 205
        Make sure the 2 plugs for the drum unit are plugged in. The small one is the drum potential sensor and without it you will only get one copy and then please wait. Dumb maybe...but make sure it is not out of toner or very very low.
        Testing 1-2-3, testing, testing. Is this thing on?
        • Fogonazo
          • Jul 2011
          • 15
          Thanks for your comment.
          I will review this and other points that have suggested.
          • SteveF
            Field Service Manager
            • Jul 2012
            • 49
            HELLO
            please wait normally sugests a bad earth on the drum
            you need to check if earth tabs are touching the inside wall of the drum
            Regards
            • mikadonovan
              • May 2008
              • 2936
              Try replacing the HDD. Sometimes a format doesn't fix this issue.
              NEVER ASSUME ANYTHING
              • JustManuals
                • Jan 2006
                • 9919
                Paul@justmanuals.com
                • Fogonazo
                  • Jul 2011
                  • 15
                  Regards
                  Thank you for your comment, but so far the machine is running and the fault has not appeared again.
                  • TonerMunkeh
                    Professional Moron
                    • 3873
                    Were there any SC codes logged in the SMC data?
                    Hit it.
