Misfeeding
  • tcypy1961
    • 773
    Misfeeding
    This Ricoh Aficio 1045 is having misfeeding problems. The paper stops regardless of tray used. It shows that the misfeed is in section C. The lead edge of the copy stops right at the switch back sensor. I have replaced this sensor but still have the same results. Not sure what is causing it to stop there everytime no matter which tray I use. Any help appreciated, thank you.
  • Athlontini
    • Jun 2012
    • 269
    Re: Misfeeding
    When you say "switch back sensor" do you mean the registration sensor? Sounds like a registration clutch or incorrect tray size settings (either via the dials or in user tools).
    • Lagonda
      • Aug 2008
      • 1649
      Re: Misfeeding
      If the paper stops at the same point to the millimetre you are looking at a faulty sensor. If the point the paper stops moves around the problem will be a clutch.
      The fuser exit sensor would be my first guess as it gets slowly roasted by the fuser.
      • Llama God
        • Mar 2009
        • 1353
        Re: Misfeeding
        Or flats on the press roller?
        Does it only do it on duplex or on single-sided as well?
        If you gently tap the gate in the interchange unit, is it sticking slightly?
        This is so vague it's untrue.
        • Venom
          Technical/IT Support
          • Nov 2009
          • 765
          IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
          • Llama God
            • Mar 2009
            • 1353
            Re: Misfeeding
            Or toner caked onto the fuser entrance guide.
            The list of possibilities without better information just goes on and on.
            • Athlontini
              • Jun 2012
              • 269
              Re: Misfeeding
              It just hit me - the sensor just beyond the fuser. Seriously check the paper size settings in the trays. Try changing the paper orientation and see if it still does it.
              • Gift
                • Mar 2011
                • 2459
                Re: Misfeeding
                So many possibilities - maybe a faulty intermediate drive clutch.
                • mikadonovan
                  • May 2008
                  • 2931
                  Re: Misfeeding
                  Originally posted by Venom
                  or could be sticky duplex solenoid….troubleshooting 101
                  Seen that a hundred times.
                  NEVER ASSUME ANYTHING
                  • Llama God
                    • Mar 2009
                    • 1353
                    Re: Misfeeding
                    I had a sticky solenoid once, but enough of my private life.
