OK guys when I enter user tool counter and then press the log in button it just beeps and wont let me . Is there a 5 mode memory clear function to erase this . If so what is it called ?
Ricoh MPC 3500 cant login
Re: Ricoh MPC 3500 cant login
Does this device the fax option and if so, when you select the fax function hard key does it say 'loading'? I had this issue before and I had to disconnect the fax board from the controller in able to access user tools. Once I reseated everything, it all went back to normal. Not sure if this is your issue, but worth a try. -
Does the printer function load when you select the Printer key? If not, reseat the Printer sd card along with the controller board. Next step would probably be to memory clear the Printer application settings (not all) - SP5801-008.Comment
2 posts for the same fault?
http://www.copytechnet.com/forums/ri...interface.html
Firstly, do you need administrator authentication turned on?
Secondly, what are the username and password that you're using?
Thirdly, can you log into the machine using the super special secret login and change the admin username and password?
Forthly, have you RTFM?
There, I'm all out of questions.Comment
Sorry, I take back part of my previous comment.
3 posts for the same fault? Are you taking the piss now?
http://www.copytechnet.com/forums/ri...upervisor.html
http://www.copytechnet.com/forums/ri...ant-login.html
Do you think that we all have nothing better to do than to read manuals for you?
Sorry, harsh but fair criticism I think you'll find.Comment
ricoh5006
Possibly, and I might be mistaken, it may have been better to have phrased this last post along the lines of the following:
"Thank you, everybody, for your helpful suggestions, I have traced the fault to the NVRAM."
Just a thought.
And, to answer your initial question, there is a code to reset the usernames and passwords.Comment
