mp c3500 not adding toner black
  • spaceman99
    replied
    Re: mp c3500 not adding toner black
    Add Toner = Print off a Non default smc if you can. Drop the NVRAM full reset. Load in the non default settins and set up the registration. VERY INPORTANT to do the reg.
    This will sort it.
    Fault caused by the Chip in the toner bottle not given the correct MR reading to the BCU causing add toner. One way to see this is turning on toner icons in SP 5--- . Your see one of the colours missing.
    This works every time for me.
    Good luck
  • Dexor
    replied
    thanks everyone for your input, it's all taken into consideration as it is likely to happen again, and likely for different reasons.
    But in this case it was the controller board - yes, controller board. We had a few machines doing weird things after thunderstorms in July and August - surge protectors are a must!
  • tcs04
    replied
    Originally posted by Llama God
    Paul will not like that...but I do!
    x2
  • Oze
    replied
    You COULD try the NVRAM/Engine clear but it's mostly the fix for the MPC2500/2800/3000 range.
    If the dev unit is well over life you may as well change that at the same time....as everyone has stated it's usually either a blocked pipe or a pump on the 3500/4500.
  • FMC
    replied
    It could be the toner bottle detect board at the back. I've had one or two of those go before after replacing the pump(s) to no avail.
  • AyJayAreDii
    replied
    Originally posted by Dexor
    pumps are working (swapped them, they are identical)
    Sometimes when they are swapped i have had to run though the add toner process a good few times to get the levels back. It is the pump too often to not to try simply replacing it.
  • Llama God
    replied
    Originally posted by Bantams
    This Parts & Service Manual can now be purchased for FREE and downloaded immediately after NO payment from
    Documents
  • Bantams
    replied
    Documents
  • JustManuals
    replied
    Paul@justmanuals.com
  • Zeldaman
    replied
  • Bantams
    replied
    Does it actually say Loading Toner when you remove and replace/refit the bottle?
    If not it could possibly be theres a Cover Open
  • Llama God
    replied
    Originally posted by Colonel Bogey
    I've only ever changed one pump. Invariably I've always found the supply pipe is blocked.
    You need to get out more, the pumps are absolute shite on these.
  • Colonel Bogey
    replied
  • duct tape
    replied
    I agree the pump is always the problem, in my experience, with this problem. I've never seen anything else on these machines.
  • Scooper123
    replied
    I can almost guarantee that this is the toner pump i must have fitted over 50 of these, if non oem toner is used then its 100% the problem. when you change it i would also give the nozzle a clean too.
    Regards
