Scan Via USB from Ricoh mp C2550
  • iscott
    • Mar 2010
    • 344
    Down loaded the Twain Driver but no scanner is recognized using on USB Workstation is Win 7 32 bit
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    Re: Scan Via USB from Ricoh mp C2550
    Scanning is via the network connection only.
    It's still TWAIN, but it will not work with USB.
    • Jomama46
      • 2900
      I think you can connect a crossover cable from the copier to the computer nw card and it might work.
      sigpic
      A+; Network +; PDI+
      • fbkhan3
        • May 2012
        • 421
        Jomoma46 is X3, does work with crossover or even with stright one with new all new laptops.
        (D041) 2 USB slots
        Left-side USB slot [C]: Used for connecting a digital camera (only works if PictBridge is installed).
        Right-side USB slot [D]: Used when installing the optional USB2.0/SD card slot
        • Llama God
          • Mar 2009
          • 1353
          USB? Wow!
          No, it'll only work via the NIC using Scan-to- email, FTP, SMB or TWAIN.
          USB, I ask you...
