Aficio 1045 ARDF
  • Antee7
    • Aug 2012
    • 9
    Aficio 1045 ARDF
    My 4 years old refurbish 1045 still up and kicking,
    issue is ARDF can't run is SP mode DF test Run as in no response.
    normal operation, copy thru ARDF in duplex and one side is no problem.
    what is suppose to be the problem.
    thanks
  • Jomama46
    • 2900
    Re: Aficio 1045 ARDF
    Are you using 6009 or the dips on the adf board?
    sigpic
    A+; Network +; PDI+
    • Antee7
      • Aug 2012
      • 9
      yes i'm using SP6009,
      i didn't touch DIP sw on the ADF board.
      thanks
      • sandmanmac
        • 3979
        thanks
        First, the machine is actually 12 years old..(that is likely the cause of your 'software glitch') and you say the DF works fine under normal operation, and It's only "free run" in SP mode that's giving you a problem. What's the big deal? Does the machine actually have a functional issue you need help solving?
        • Jomama46
          • 2900
          My best guess is you dont know how to execute 6009, so look in your sm at the dips for free run. much more extensive,
          If you're just f'ing around, don't.
          sigpic
          A+; Network +; PDI+
          • Llama God
            • Mar 2009
            • 1353
            The pulley will have broken.
            I don't know why I said that.
            I don't know why I said anything.
            I don't know what this thread is for.
            Christ...
            • Antee7
              • Aug 2012
              • 9
              i know all of you guys have lots of experience in fixing copiers.
              DF test run helps a lot in fixing ARDF intermitent jam problem you can run several sheet of paper and the copier is not printing, i think you know what i mean.
              i knew how exactly to use 6009-1/2
              is there a dips setting to bypass test run since sp mode enable software is not functional.
              thanks to all who reply
              • teebee1234
                • Jul 2008
                • 1670
                If the device has the Document Server function, just scan to that all day. No wasted paper and delete the files when done.
                The dip switch settings are as follows....
                DPS101
                1 2 3 4 Description
                0 0 0 0 Normal operating mode, with/without stamp.
                0 0 0 1 Not used
                0 0 1 0 Not used
                0 0 1 1 Not used
                0 1 0 0 Feed motor rotation (feed mode) 4400 pps (1-2 phase)
                0 1 0 1 Feed motor rotation (pull-out mode) 6100 pps (1-2 phase)
                0 1 1 0 Scanner motor rotation 4320 pps (2 phase)
                0 1 1 1 Inverter motor rotation 6000 pps (1-2 phase)
                1 0 0 0 Free run: one-sided original 100%
                1 0 0 1 Free run: one-sided original 30%
                1 0 1 0 Free run: one-sided original 71%
                1 0 1 1 Free run: one-sided original 200%
                1 1 0 0 Free run: two-sided original 100%
                1 1 0 1 Free run: two-sided original 200%
                1 1 1 0 Free run: one-sided (fax mode) 32.6%
                1 1 1 1 Free run: one-sided (mixed original size mode) 100%
                • Antee7
                  • Aug 2012
                  • 9
                  DPS101
                  1 2 3 4 Description
                  0 0 0 1 Not used
                  0 0 1 0 Not used
                  0 0 1 1 Not used
                  thanks to this precious information
