Just got post script installed on machine...now what?
Ricoh MP C3500---Need help to print using imac
Tags: None
Re: Ricoh MP C3500---Need help to print using imac
is that the post script chip installed in the machine itself?
have you downloaded and installed the driver and configured it?
make sure the print driver you have is for the correct mac os version.
if its an older os then you might be out of luck with it.$hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load -
Samoa
Found the driver, downloaded and installed! Didn't realize the post script chip was the missing piece. Thought it would have been more complicated than that. I appreciate the response.Comment
Samoa
lol I wasn't joking. Its all good now. Whats ppd? I typed in 55378008 and turned it upside down. I can't make out what it says...something less....HELP!Comment
The PPD is the "driver" for Macs - if you download that and run it then you'll get the instructions for how to install it.Comment
