c2550
  • Jomama46
    • 2900
    c2550
    Got this c2550 that wont initialize. I have the finisher out, the DF unplugged, the duplexer unplugged and the drawers out.
    When I turn it on, the controller leds light , I hear one beep and the display reads "wait". And thats all. I have swapped the controller and the HD, tried it with and without the RAM sticks. Proper power is being applied at the input to the controller board.
    What am I missing here????
    sigpic
    A+; Network +; PDI+
  • francisco
    • Nov 2009
    • 168
    Re: c2550
    display (please wait) for a long time?
    change HD or format
    • Jomama46
      • 2900
      Re: c2550
      Tried a new HD, same-o same-o.
      sigpic
      A+; Network +; PDI+
      • Jomama46
        • 2900
        Re: c2550
        Also no fuser lamps.
        sigpic
        A+; Network +; PDI+
        • banginbishop
          grumpy old git
          • Oct 2007
          • 894
          Re: c2550
          are you getting power to the fuser? because normally the power supply supplies the power direct to the fuser,also to dc board but I would suspect you already know that.
          Incontinentia Buttocks
          • Polo-022
            • Sep 2007
            • 486
            Re: c2550
            P.S.U. (No initialization, no fuser lamps...) Did you check +24V lines Jo???
            Is this a call-back issue?
            • Jomama46
              • 2900
              Re: c2550
              I think I will check that PSU again.
              sigpic
              A+; Network +; PDI+
              • Jomama46
                • 2900
                Re: c2550
                All the fuses are good, voltage on both sides. 24V available in all the right places. 5V too.
                There was a dufus working on this machine before me and it started out with BYpass misfeeds, thats why I have the duplexer unplugged. So the PSU was a good idea too.
                I dont have another 2550 controller but I have a 2050. I know they are different but I think if the controller is the problem at least the symptoms will change.
                Shit, I'll throw another PSU in there too. I just dont want to have to buy another controller if I dont have to, $900.
                sigpic
                A+; Network +; PDI+
                • fbkhan3
                  • May 2012
                  • 421
                  Re: c2550
                  yes you know that but it's just a thought,before throwing new PSU in spend some time and save some bucks.
                  Try to unplug connectors on I/O one by one and turn it on,specially the one which goes to bypass and duplex er or all of them step by step,
                  good luck!
                  • banginbishop
                    grumpy old git
                    • Oct 2007
                    • 894
                    Re: c2550
                    i would check for trapped wires myself now someone else was working on it before you, had a similar incident a year back on an mpc, engineer removed the duplex unit to remove the paper feed unit (mpc) traped a wire and m/c wouldnt boot up - had to track back what he had done.
                    i've also trapped a thermistor wire to give a crossed zero error giving no power to the lamps- strange what trapped wires will do.
                    • Jomama46
                      • 2900
                      Re: c2550
                      good thoughts, thx
                      sigpic
                      A+; Network +; PDI+
                      • BLADE
                        former propeller tester
                        • 478
                        Re: c2550
                        does that model have 4 trays with a connector at the back? check the connector for the lower 2 trays (if it has them) is on straight
                        • tcs04
                          FORMER Techie
                          • 1183
                          Re: c2550
                          Does the m/c boot with the fuser out and doors open? (only to "reset fuser" of course)
                          • Oze
                            Ricoh Fanboy
                            • 1663
                            Re: c2550
                            I had the same fault a little while back except due to a trapped wire in the duplex connector the machine was tripping the fuse-box of the building....blew the glass fuses on the psu and took out the I.H.Inverter board...go figure :/
