MPC2550 SC
  • blackdog
    • Jun 2012
    • 211
    MPC2550 SC
    Hope all is well in your neck of the woods.
    Delivered a MPC2550 a week ago, customers IT dept was setting up network and emailed me yesterday a pic of display showing a SC865-01.
    No service manual on this model. MPC3000 series I do have.
    Anywho, do I need to replace hard drive or will a format do the trick. Only 180K on this box.
    Also, does this model have two drives? If so would I have to replace both drives? 80Gb each? Seagate/Western?
    Any other suggestions I might need would be helpful.
    Thank you
  • Llama God
    • Mar 2009
    • 1353
    Re: MPC2550 SC
    Right off the top of my head, what with it being Saturday and all, this has a single 2.5" SATA drive. The capacity, at a guess, is 60GB but you can put a bigger on in.
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      Re: MPC2550 SC
      DO a full hard drive format before you replace the drive. It maybe the machine was not shut down correctly and the lead data on the disk is corrupted.
      Mystic Crystal Revelations
      • JustManuals
        • Jan 2006
        • 9919
        Re: MPC2550 SC
        Paul@justmanuals.com
        • tcs04
          FORMER Techie
          • 1183
          Re: MPC2550 SC
          you may get away with just the IMH format. if it works you don't have to reload the address book etc
          • blackdog
            • Jun 2012
            • 211
            Re: MPC2550 SC
            Hey Paul,can you please change that Alfred Newman Clown.
            It gives me nightmears!
            • blackdog
              • Jun 2012
              • 211
              Re: MPC2550 SC
              Thanks guys, full format and that's it? No lost data? That's it? To good to be true.
              This sounds much like a Toshiba. When not shut down correctly several times or more, drive error code pops up, format drive and all is well again.
              • blackdog
                • Jun 2012
                • 211
                Re: MPC2550 SC
                Did as you suggested and all is well on the western front.
                There was also a sc925 code on lower left of display.
                Thanks again
                • tcs04
                  FORMER Techie
                  • 1183
                  Re: MPC2550 SC
                  Originally posted by blackdog
                  Did as you suggested and all is well on the western front.There was also a sc925 code on lower left of display.Thanks again
                  Thanks for the feedback... I would update the firmware as a precaution (SC 925 = netfile error)
                  • blackdog
                    • Jun 2012
                    • 211
                    Re: MPC2550 SC
                    Like to pick your brain for a moment.
                    Which is the best access point to print all current settings on box.
                    The setting sheet is not under jam info front door.
                    Also aquiring firmware? Best source.
                    Thanks, me
                    • tcs04
                      FORMER Techie
                      • 1183
                      Re: MPC2550 SC
                      Thanks, me
                      SP5990 - 1
                      Re the firmware, I assume you have access to your local Ricoh technical site?
                      • Llama God
                        • Mar 2009
                        • 1353
                        Re: MPC2550 SC
                        Thanks, me
                        Thanks, Me is the best ending to a post of all time!
                        Print off the SMC data in SP5990-001.
                        Regarding the firmware, either download it from Tessa or I'll PM you a link to a site which will send you the firmware.
                        • blackdog
                          • Jun 2012
                          • 211
                          Re: MPC2550 SC
                          Your awesum man.
                          I see firmware in my PB. Is this the baby?
                          • Llama God
                            • Mar 2009
                            • 1353
                            Re: MPC2550 SC
                            Your awesum man.
                            Not from me, but there are other helpful people on here who will help you out.
